In this sample, you may use actorTransform function to transform the
actor, including resizing and re-locating. Your web audiences will then
interact more with the actor when it is talking or idling. In addition, it
allows the viewers to move and resize the actor to another position in
the player so that they are able to see the background image content
without hiding the
actor.
Using the actorTransform Function
Scale:
Position X(0~100):
Position Y(0~100):
Duration:
Controls Behaviors
This sample contains 3 buttons and 4 edit boxes, their behaviors are:
Click the first button, Actor Transform1, to resize and move the
actor to a given set of transform values (80, 60. Size: 80%) in 5 seconds.
Click the second button, Actor Transform2, to resize and move the
actor to another given set of transform values (40, 40. Size: 50%) in 3
seconds.
Type the numbers into the edit boxes, Scale, Position X, Position Y,
and Duration, and then click the button, Custom, to load
resize and move the actor to still another custom transform position in
the given amount of seconds.
Copy and paste the codes in-between the <head> and
</head>
tags of your custom web page.
The purposes of the functions:
$(function ():
This function defines the address, the position of
the CrazyTalk Web Player in the custom web
and loads and plays a default project (Actor_sizeposition.uctproject)
with an assigned idle motion (CTDefWebPreview.uctidle) once
your page is opened.
functionTransform1(): This
function transforms the current actor to a given size
and position in 5 seconds.
functionTransform2(): This
function transforms the current actor to another
given size and position in 3 seconds.
functionTransform3(): This
function collects values from certain text-editing
boxes defined in the body block and transforms the
current actor accordingly.
The adjustable codes in the functions: $(function ()
Replace the below address of the CrazyTalk Web Player with the one within your self-hosting
server. https://www.reallusion.com/crazytalk/Unity/samplecode/CTWebPlayer.unity3d
player.loadProject(){...}:
For more information about the modification method to the
function loading a default project, please refer to the
Loading Projects section.
functionTransform1 and
Transform2
player.actorTransform({...}):
Scale: This value transforms the
current actor to a custom size (as a
percentage value of the original actor).
positionX: This value horizontally
moves the
current actor to a custom position (in
relation to the width of the web player).
positionY: This value vertically
moves the
current actor to a custom position (in relation to the height of the web player).
duration: This value determines the
transform time in seconds. The minimum
value is 0.2.
<divid="unityPlayer"style="width:640px;height:480px;"></div>
<inputtype="button"value="Actor Transform1"onclick="Transform1()"class="button"/><inputtype="button"value="Actor Transform2"onclick="Transform2()"class="button"/>
Scale:<inputtype="text"id="txtScale"style="width:30px"/>
Position X:<inputtype="text"id="txtX"style="width:30px"/>
Position Y:<inputtype="text"id="txtY"style="width:30px"/>
Duration:<inputtype="text"id="txtDuration"style="width:30px"/><inputtype="button"value="Custom"onclick="Transform3()"class="button"/>
Web Player
Copy and paste the codes from <div>
to </div> into the position
where you want to embed the web player in-between the
<body> and </body>
Modify the numbers after the width: and
height: parameters in the first line to customize
the size of the player.
Buttons with Pre-defined Settings
Copy the <input.../> lines
(line 7 and line 8) to the positions
where you want to embed the buttons in-between the
<body> and
</body> tags of
Please note that:
The function and the button that calls it must be
individually put within the head and body blocks in pairs.
You can only copy and paste the desired buttons and the functions
to your custom web pages.
These two <input.../> lines form two buttons on the web. Each of them will call the function declared
within the head block after being clicked.
Controls for Customizing Settings
Copy the Scale:<input.../> line to add a text-editing box in your web page for entering a desired size of the
actor as a percentage value (100 means
100% size of the actor).
Copy the Position X:<input.../> line to add a text-editing box in your web page for entering a desired
horizontal position of the actor as a percentage value (50 means
the mid point of the player width).
Copy the Position Y:<input.../> line to add a text-editing box in your web page for entering a desired
vertical position of the actor as a percentage value (50 means the
mid point of the player height).
Copy the Duration:<input.../> line to add a text-editing box in your web page for entering a desired size of the
actor (1 means
1 second).
Copy the last <input.../> line to the position
where you want to embed the button in-between the
<body> and
</body> tags of
your custom web page. This button will collect the values
the viewer enters in the text-editing boxes listed above and
then execute the transformation of the actor by calling the
function defined in the head block.
