In this sample, you may use the loadScript function to toggle and load different
scripts for an actor
by pressing buttons with specific behaviors. Copy and paste the codes to your custom web page
so that you can have an actor display different scripts and expressions.
Using the loadScript Function
Controls Behaviors
This sample contains 2 buttons, their behaviors are:
Click the first button, Script1, to load and apply the first
script (Scripts.uctscript)
to the actor, and auto-play after it is loaded. Meanwhile, a message is
put in the Console panel of your web browser after the script is
loaded.
Click the second button, Script2, to load and apply the second
script (Script2.uctscript)
to the actor, the script will not auto-play and you will need to click the
play button to play the script. Meanwhile, a message is
loaded.
Copy and paste the codes in-between the <head> and
</head>
tags of your custom web page.
The purposes of the functions:
$(function ():
This function defines the address, the position of
the CrazyTalk Web Player in the custom web
and loads a default
actor (Scripts.uctModel) with an assigned
idle motion (CTDefWebPreview.uctidle) once
your page is opened. This function is a must because you need to have an actor before loading and
assigning scripts to it.
functionScript1(): This function loads
a script (Scripts.uctscript) and plays the
script instantly. It also prompts a message text,
Script1 loaded!, in the console panel.
functionScript2(): This function loads
a script (Script2.uctscript) without playing
back but having the actor remains idling. It also prompts a message text,
Script2 loaded!, in the console panel.
The adjustable codes in the functions: $(function ()
Replace the below address of the CrazyTalk Web Player with the one within your self-hosting
server. https://www.reallusion.com/crazytalk/Unity/samplecode/CTWebPlayer.unity3d
player.loadProject(){...}:
For more information about the modification method to the
function loading a default project, please refer to the
Loading Actors section.
function Script1
and Script2
Replace the below addresses of the *.uctmodel files with the ones
where you have uploaded your custom actors.
In Script1: https://www.reallusion.com/crazytalk/Unity/samplecode/SampleCode5/Scripts.uctscript
In Script2: https://www.reallusion.com/crazytalk/Unity/samplecode/SampleCode5/Script2.uctscript
Note:
If the custom script files are uploaded to the identical server where your custom web
pages are, then simply change the entire
addresses (http://...uctscript) to
the file names of the custom scripts.
Otherwise, you must replace the
entire addresses with the complete addresses
(URL) of the custom script files.
playAfter: This value determines the
seconds for the player to wait before starting play
the true content of the project. A negative number
means never to play back.
loaded: function (status) {}: If you want to execute more commands, functions or
methods after the custom script is loaded, then add them into this function in-between the curly brackets.
They will instantly be executed after the custom
script is loaded.
In this case, the console panel will display Script1 loaded! or
Script2 loaded!.
Copy and paste the codes from <div>
to </div> into the position
where you want to embed the web player in-between the
<body> and </body>
Modify the numbers after the width: and
height: parameters in the first line to customize
the size of the player.
Controls for Loading Scripts
Copy the
<input.../> lines to the positions
where you want to embed the buttons in-between the
<body> and
</body> tags of
Please note that:
The function and the button that calls it must be
individually put within the head and body blocks in pairs.
You can only copy and paste the desired buttons and the functions
to your custom web pages.
These two
<input.../> lines form two buttons on the web. Each of them will call the function declared
within the head block after being clicked.
