In this sample, you can simply use the showPlaybar function to hide or show the
play bar at the bottom of the web player, because sometimes you do not
want the audiences to play, stop the project you have prepared to show them.
Using the showPlaybar Function
Controls Behaviors
This sample contains 2 buttons, their behaviors are:
Click the first button, Show, to show the play bar.
Click the second button, Hide, to hide the play bar.
Copy and paste the code in-between the <head> and
</head>
tags of your custom web page.
The purposes of the functions:
$(function ():
This function defines the address and the position of the CrazyTalk Web Player
in the custom web page and initializes the player;
meanwhile, loading a project (Cute_Dog.uctProject) and an idle motion
(Exhausted.uctidle)
file without auto-playing back.
functionShowPlayBar(): This
function shows the play bar.
functionHidePlayBar(): This
function hides the play bar.
The adjustable codes in the functions: $(function ()
Replace the below address of the CrazyTalk Web Player with the one within your self-hosting
server. https://www.reallusion.com/crazytalk/Unity/samplecode/CTWebPlayer.unity3d
player.loadProject("...",{}):
Please refer to the
Loading Projects for more information about
the adjustable parts in this function.
functionShowPlayBar(),
HidePlayBar()
player.showPlaybar(boolean): This line
determine to show or hide the play bar. The possible
values are:
Copy and paste the codes from <div>
to </div> into the position
where you want to embed the web player in-between the
<body> and </body>
Modify the numbers after the width: and
height: parameters in the first line to customize
the size of the player.
Buttons with Pre-defined Settings
Copy the <input.../> lines
to the positions
where you want to embed the buttons in-between the
<body> and
</body> tags of
Please note that:
The function and the button that calls it must be
individually put within the head and body blocks in pairs.
You can only copy and paste the desired buttons and the functions
to your custom web pages.
These <input.../> lines form
two buttons on the web. Each of them will call the function declared
within the head block after being clicked.
