In this sample, you may use bind function to retrieve event data from
the mouse, such as clicking or the position of the mouse.
This is a very powerful function which helps to enable user actions
such as changing avatar expressions, talking scripts, altering background images, etc.
You may refer to the Mouse Event Example page to
learn more about the use of the clicking event of the mouse to show or hide a custom
foreground image.
Using the bind Function
Mouse Action:
X:
Y:
Controls Behaviors
This sample contains 1 player and 3 labels, their behaviors are:
You are able to click with the left, middle and right mouse buttons on
the player. The player will pass the clicking events.
The first label (labAction) shows the clicking events.
The second and third labels (labX, labY) show the position of the cursor within the
player.
Copy and paste the lines of code in between the <head> and
</head>
tags of your custom web page.
The purposes of the function:
$(function ():
This function defines the address and position of
the CrazyTalk Web Player in the custom web page.
It contains three methods -
player.loadProject(){...}: This
method loads and plays a default project (Interaction_mouse_event)
with an assigned idle motion (CTDefWebPreview.uctidle) once
your page is opened.
player.bind("mousemove", function (event){...}):
This method gets the position (x, y) of the
mouse cursor on the web player and assigns
them in text format to two labels, labX and labY.
player.bind("click", function (event){...}):
This method gets the events of the
them in text format to a label, labAction.
Note:
Please note that the label names mentioned above must be identical to the ones
given to the controls
within the body block.
The adjustable code in the function: $(function ()
Replace the below address of the CrazyTalk Web Player with the one within your self-hosting
server. https://www.reallusion.com/crazytalk/Unity/samplecode/CTWebPlayer.unity3d
For more information about the modification method for loading a default project, please refer to the
Loading Projects section.
Adjust the codes within the last method to change the
reaction of the web player when mouse events occur. The
current reactions generated by the code event.button are:
case0:
Assign a string, "Left mouse button pressed.", to variable Action.
case1:
Assign a string, "Middle mouse button pressed.", to variable Action.
case2:
Assign a string, "Right mouse button pressed.", to variable Action.
case3:
Assign a string, "No button pressed.", to variable Action.
Note:
You are free to add different main functions you have learned in the other pages of sample code into these cases so that these functions can be triggered
by certain mouse events.
Copy and paste the codes from <div>
to </div> into the position
where you want to embed the web player in-between the
<body> and </body>
Modify the numbers after the width: and
height: parameters in the first line to customize
the size of the player.
Controls for Showing Events
These codes are for showing the mouse events. You may optionally copy and paste them into
your custom web pages, which will not cause any issues, allowing the bind function
to work perfectly even if your web pages do not contain these codes.
Copy the Mouse Action:<label.../> line to add a
label to show the mouse events on the player.
Copy the X:<label.../> line
if you want to show the X position of the mouse cursor on
the player in percentage.
Copy the Y:<label.../> line
if you want to show the Y position of the mouse cursor on
Note:
Please note that these label names mentioned above must be identical to the ones
within the head block.
Copy the last <input.../> line to the position
where you want to embed the button in-between the
<body> and
</body> tags of
your custom web page. This button will collect the values
the viewer enters in the text-editing boxes listed above and
then execute the gazing behavior for the actor by calling the
function defined in the head block.
