In this sample, you may use the loadActor function to toggle and load different
actors
by pressing buttons with specific behaviors. Copy and paste the code to your custom web page
so that you can have different characters talking in identical scenarios.
Using the loadActor Function
Controls Behaviors
This sample contains 2 buttons, their behaviors are:
Click the first button, Actor1, to load and show the first
actor (Actor.uctmodel) with idle motion (CTDefWebPreview.uctidle) after the playback stops.
Click the second button, Actor2, to load and show the second
actor (Actor2.uctmodel) with a message shown in the Console panel
of your web browser after the actor is loaded. However, the actor is not
assigned with
any idle motion after the playback stops.
Copy and paste the code in-between the <head> and
</head>
tags of your custom web page.
The purposes of the functions (you may determine if you want to copy one or more of the
following 4 functions into your page):
$(function ():
This function defines the address, the position of
the CrazyTalk Web Player in the custom web
and loads and plays a default project (Actor.uctproject) once
your page is opened.
functionnnActor1(): This function loads
another actor (Actor.uctmodel); meanwhile,
assigning an idle motion (CTDefWebPreview.uctidle) to the newly loaded actor.
functionActor2(): This function loads another
actor (Actor2.uctmodel) without idle motion. In addition, it also pops up a messsage text,
Actor loaded!, in the console panel.
The adjustable codes in the functions: $(function ()
Replace the below address of the CrazyTalk Web Player with the one within your self-hosting
server. https://www.reallusion.com/crazytalk/Unity/samplecode/CTWebPlayer.unity3d
player.loadProject(){...}:
For more information about the modification method for the default project function, please refer to the
Sample Code 3 - Load Projects section.
functionActor1 and Actor2
Replace the below addresses of the *.uctmodel files with the ones
where you have uploaded your custom actors.
In Actor1: https://www.reallusion.com/crazytalk/Unity/samplecode/SampleCode4/Actor3.uctmodel
In Actor2: https://www.reallusion.com/crazytalk/Unity/samplecode/SampleCode4/Actor2.uctmodel
Note:
If the custom actor files are uploaded to the identical server where your custom web
pages are, then simply change the entire
addresses (http://...uctmodel) to
the file names of the custom actors.
Otherwise, you must replace the
entire addresses with the complete addresses
(URL) of the custom actor files.
showActor: The Boolean (true for
false) value determines if the character will be shown
or hidden when the project is loaded.
functionActor1
idleMotionUrl: Replace the below address of the *.uctidle file with the one
where you have uploaded your custom idle motion. https://www.reallusion.com/crazytalk/Unity/samplecode/SampleCode4/Affirmative.uctidle
Note:
If the idle motion file is uploaded to the identical server where your custom web
address (http://...uctidle) to the file name of the
custom idle motion.
entire address with the complete address
(URL) of the idle motion file.
functionActor2
loaded: function (status) {}: If you want to execute more commands, functions or
methods after the custom actor is loaded, then add them into this function in-between the curly brackets.
They will instantly be executed after the custom
actor is loaded.
In this case, the console panel will display Actor loaded!.
Copy and paste the codes from <div>
to </div> into the position
where you want to embed the web player in-between the
<body> and </body>
Modify the numbers after the width: and
height: parameters in the first line to customize
the size of the player.
Controls for Loading Actors
Copy the
<input.../> lines to the positions
where you want to embed the buttons in-between the
<body> and
</body> tags of
Note:
The function and the button that calls it must be
individually put within the head and body blocks in pair.
You can only copy and paste the desired buttons and the functions
to your custom web pages.
These two <input.../> lines form two buttons on the web. Each of them will call the function declared
within the head block after being clicked.
