In this sample, you may use the bind function to perform given actions for the player's playback status, such as start, playing, pause and stop.
Using the bind Function
Current Time:
Total Time:
Controls Behaviors
This sample contains 1 player and 2 labels, their behaviors are:
When the project starts to play, an image (7.jpg) is loaded as the background.
When the project is playing, the texts of the labels (labTime,
labTotalTime) will be set to show the current time and the total time of
the project.
Clicking the pause button while the player is playing will cause a foreground
image to show (Logo.jpg). Click on the foreground logo to open a new
browser page with a given address (www.reallusion.com).
Click the stop button while the player is playing, the actor will be
replaced with a new one (Interaction_animation_callback2.uctmodel), and another script (Interaction_animation_callback2.uctscript) will also be loaded.
Copy and paste the code in-between the <head> and
</head>
tags of your custom web page.
The purposes of the functions:
$(function ():
This function defines the address and position of
the CrazyTalk Web Player in the custom web page.
It contains two methods -
player.loadProject(){...}: This
method loads and plays a default project (Interaction_animation_callback.uctproject)
with an assigned idle motion (CTDefWebPreview.uctidle) once
your page is opened.
player.bind("playerstatus", function (event){...}):
This method detects events in order to
react.
event = startplay:
This event will load and show an image
(image.jpg) as the background.
event = playing:
This event will set the text of labels
(labTime, labTotalTime) to
show the current playback time and the
total length of the project.
event = pause:
(Logo.png) as a foreground. Click on the
foreground to open a new browser page
event = stop:
This event will load and show another
actor
(Interaction_animation_callback.uctmodel) with a new script (Interaction_animation_callback.uctscript).
Note:
Please note that the label names mentioned above must be identical to the ones
given to the controls
within the body block.
functiononClick(): This function opens a new web browser and loads a given web site
(https://www.reallusion.com).
The adjustable codes in the functions: $(function ()
Replace the below address of the CrazyTalk Web Player with the one within your self-hosting
server. https://www.reallusion.com/crazytalk/Unity/samplecode/CTWebPlayer.unity3d
For more information about the modification method to the
function loading a default project, please refer to the
Loading Projects section.
event = startplay:
method to the loading a background
image function, please refer to the
Loading Backgrounds
section.
event = pause:
image function , please refer to the
Loading Foreground
section.
event = stop:
method to the loading a model and a
script function, please refer to the
Loading Actors and
Loading Scripts sections.
Note:
You are free to add different main functions you have learned in the other pages of sample code into these methods so that
these functions can be triggered
by certain playback events.
function onclick()
Replace the original address (https://www.reallusion.com) with
a desired one you want to direct the audience to.
<divid="unityPlayer"style="width:640px;height:480px;"></div>
Current Time:<labelid="labTime"style="color:red"></label>
Total Time:<labelid="labTotalTime"style="color:red"></label>
Web Player
Copy and paste the code from <div>
to </div> into the position
where you want to embed the web player in-between the
<body> and </body>
Modify the numbers after the width: and
height: parameters in the first line to customize
the size of the player.
Controls for Showing Events
These lines of code are for showing the playback events. You may optionally copy and paste them into
your custom web pages; which will prevent any issues and allow the bind function
to still work perfectly even if your web pages does not have this code.
Copy the Current Time:<label.../> line to add a
label to show the current time when the player plays back.
Copy the Total Time:<label.../> line
if you want to show the total length of the project.
Note:
Please note that these label names mentioned above must be identical to the ones
within the head block.
