Votes
Product:
iClone 8
Version:
8.51
Status:
Not Reproducible
Issue 11652
iCLONE8 KEEPS CRASHING BY IMPORTING WONDER DYNAMICS FBX MOCAP ANIMATION
1 Create any AI mocap animation from WD and download the mocap fbx to your PC
2 In iClone use any CC4 actor to start ( I used Kevin, Mannequin Male, Motion Dummy, etc.) with the same result.
3 Locate the AI WD mocap file on your selected download folder and drag and drop it over the CC4 Actor character you choose.
4 On "motion import settings" select wonderStudio, or (any Mixamo profile in desperation to make it work).
You can disable or keep enabled "Keep Root Motion" it doesn't matter it will crash either way.
(I also make sure to have foot and hand contact cases disabled to prevent any position issues on the modify panel and have selected my render settings in quick mode just in case.) Again, It will crash.
5 Click on Convert All..
Actual Result:
An import animation motion prompt will show up loading and will crash in around 5 to 10 seconds.
Expected Result:
To have the Wonder Studio Profile work and get their mocap animations working in iClone 8 with CC4 characters.
OS: Windows 11
  •  2
  •  118
Submitted byTigernaut Nov 23, 2024
COMMENTS (2)
Feedback Tracker Admin Feb 4, 2025
Hi Tigernaut,
We would like to follow up and check if you are still experiencing this issue.
If the issue persists, could you kindly provide your WD mocap file to us?
Best Reguard
Jasmine
Reallsuion
Feedback Tracker Admin Jan 3, 2025
Hello Tigernaut,
Thank you for your feedback!
We can't repeat reproduce it, could you provide us with your file so that our engineers can investigate the issue?
Please upload the file to a cloud drive and share the download link with us. If needed, you can set your reply with the link as a private message.
Best Reguard
Jasmine
Reallsuion
