Issue 11476
Strong suggestion transperent Grid and SHIFT+Q (BUG?)
I would like to suggest using a transparent grid like seen in here
https://courses.reallusion.com/webinar/archive?v=revolutionized-blender-workflow-for-creating-look-alike-3d-characters-from-photos in headshot photomode. This would make in my opinion make fitting the headshape to the photo WAY easier then the current method.
Additionally i would like to suggest (BUG?) making SHIFT+Q not snap to a locked screen size when Image matching tools are anabled. Problem: When zoomed in while Image matching tools are active (SHIFT+Q), working on details, pressing SHIFT+Q again makes the screen snap down to a fixed size. This is very annoing because you have to permamantly zoom in and out when checking the results of your work. SHIF+Q is the most used key combination in photo mode, i wonder noone else has complained about this before. To verify this do the following:
- Load an image into Headshot
- Activate Sculpt Morph and SHIFT+S Image matching tools with SHIFT+Q
a)- Zoom in , make adjustements
- Press SHIFT+Q to quickly compare the result with the original photo
- Notice when pressing SHIFT+Q CC zooms out !
- Press SHIFT+Q and zoom again , goto step a
In my opinion the photo should stay at the current zoom level when pressing SHIFT+Q until the user decides to zoom out again
Please also refer to
https://www.reallusion.com/FeedBackTracker/Issue/Shift-Q-not-working-as-expected
Submitted byK_Digital
Aug 20, 2024
