Votes
Product:
iClone 8
Version:
8.12
Status:
Assigned
Issue 9300
METAHUMAN - UNREAL MARKET ANIMATION PROBLEM / IClone 8
Hi, When I run the character named Metahuman "m_med_nrw_body", which I downloaded from your site, on I Clone 7 and use this animation file that I sent you, the animation works properly as in the image. But when I open the same Metahuman character in I Clone 8 and use the same animation on the character in I Clone 8, the position of the hands changes. If the model and animation file are the same and work fine in I Clone7 but not in I Clone 8, the problem is not with the files. The reason it works fine in I Clone 7 is probably because we added the animation using 3DxChange. Unfortunately we cannot use this plugin in I Clone 8 because you removed it and automated it in I Clone 8. This causes the same animation to look different in different program versions for the same character. But I want it to look like I Clone 7 using I Clone 8. I am attaching the relevant animation file here. You can control the animation using Windows 3D, Blender or any 3D program. What you will see is the position of the hands as in IClone 7, that is, as it should be. In iClone 8 this animation does not work as it should. You need to solve this urgently. I haven't been able to shoot my animation video for a long time.
Regards...
Nurettin Öney
OS: Windows 10
  •  0
  •  283
Submitted bynurettinart Feb 9, 2023
COMMENTS (0)
