Votes
0
Product:
iClone 8
Version:
8.4
Status:
Active
Issue 11073
Global light Control in iC8 that can be animated to 100% absent of light/visuals and lower in CC4
As I learned from a previous Feedback post I created, that several functions have to be changed in order to get 100% darkness which isn't very intuitive and doesn't make sense if you only want to make your scene completely void of light.
current solution: Change Ambient light to black, 0 IBL strength, scene lights set to 0, disable active image in project settings.
There should be a threshold that the last remaining light triggers all light or other non light, visible sources to fade out.
Now it should be easy to see why many struggle setting up their scene lighting when they expect that turning lights off should completely make the scene completely dark. Fixing this issue will help get users quickly up to speed setting up quality scenes, otherwise what should be a simple task, settings are convoluted and redundant. -Work & learn easy, not hard.
OS: Windows 11
  •  1
  •  227
Submitted byAscensi Dec 31, 2023
COMMENTS (1)
outdadoor Aug 17, 2024
And lighting level should be key-able!
