How to Use the Flap Dummy? |
Introduction of the Flap Dummy |
A. |
Different Hair Ornaments: Accessories & Props |
B. |
Adjust the appropriate location via Transform Tool. |
C. |
Creative ideas: Hair Ornaments can be attached to other parts of the body. |
For more details, please follow the step-by-step instructions below. |
A.Different Hair Ornaments:
According to usage, this pack provides two kinds of hair ornaments. |
Accessories: The already-positioned accessories (for Default Jana and Dylan). |
Props : Users place them wherever they want.
B.Adjust the appropriate location via Transform Tool.
B-1 |
Load any Avatar.
Load the Scalp Base, and Hair Ornament that you want. |
B-2 |
Adjust Hair Ornaments position, scale, and rotation settings via Transform Tool. |
C.Creative ideas: Hair Ornaments can be attached to other parts of the body.
C-1 |
Apply any Hair Ornament in Actor/Accessories. (eg. Machine Socket_L). |
C-2 |
After the Layout Base is loaded, detach it immediately.
(When it is detached, it became a prop.) |
Delete unused part in the Scene Manager.. |
C-3 |
Move/Scale the Hair Ornament to the appropriate position/size via Transform Tool. |
C-4 |
Switch to Move/Rotate mode. |
Hold down the Ctrl key, and then move/rotate the Hair Ornament. Upon the release of the Mouse key, the object will be duplicated. Keep doing this until all objects are completed. |
C-5 |
Attach the Hair Ornaments to body parts according to their location. |
Switch to Select Mode and click on one of these ornaments.
Right click on it to execute attach. |
Click on the closest body part. And you will see the object is attached to the body part. |
Keep doing this until all objects are attached to the appropriate body part, and you can apply motions to see the result. |
