How to Assemble the Skirts?
  How to Create Customized Avatars?
How it works
  A. Create an Avatar
  B. Place Hair Segments & Ornaments to the appropriate location.
  C. Check Materials of Hair Segments to decreases the size of the files.
  D. Attach Hair Segments to the Avatar.
For more detail, please follow the step-by-step instructions below.
A.Create an Avatar
A-1 Apply any Avatar & Scalp Base. (eg. G3 Nude Female & Scalp Base_Alien.)
A-2 According to you will, apply the new face, eyes or edit Skin Textures. Edit the textures for other channels (Specular, Reflection and Glow...etc.) in Material & Texture Settings.
B.Place Hair Segments & Ornaments to the appropriate location.
B-1 Apply the Hair Segments that you want..
B-2 Place and copy Hair Segments to the appropriate position. Adjust scale, and rotation settings via the Transform Tool.
  For more details, please go to Step B in ''How to Use the Hair Segments''.
C.Check Materials of Hair Segments to decreases the size of the files.
All the duplicated props will only load the material texture of the first pop. It dramatically decreases the size of the files.
C-1 Make sure whether all the hair segments share a material.
  Choose the first Hair Segment from the Scene Manager.
  If they don't change color together, it means that they are not using the same Material.
C-2 Assign material to hair segments using the Pack & Paint Function.
  Click the Paint button and click on every hair segment that didn't change color.
  Through the Paint function, all the hair segments of the same type are using the same material.
C-3 Edit all the texture of Hair Segments at the same time.
  Select any Hair Segment and Launch Blend Texture in Modify/Material & Texture Settings.
  According to your will, edit the texture in 2D Software (eg. Photoshop).
  Save the texture and click on Update in iClone.
  You can see all the segments will change at the same time.
  Tip. You can also choose any hair segment and change its color at the same time.
D.Attach Hair Segments to the Avatar.
D-1 Attach the Hair Segments/Ornaments to body part according to their own location. For more details, please go to Step B in ''How to Use the Hair Ornament''.
Top
Copyright © 2010 Reallusion, Inc.
