C-1 |
Turn on the Swing Dummy. |
Select the Swing Dummy, and Right-click to select Perform/Swing Leftward & Rightward. |
Please do not interrupt the animation until the animation finishes naturally.
Make sure that the Preference/Enable Spring/Flex Effect box is checked. |
C-2 |
Change the speed of the swings. |
Select Swing Dummy in Scene Manager, and open Timeline. Make sure that Loop/Speed Switch box is not checked. |
C-3 |
Select the Animation Clip in the Perform Channel, and drag it. |
The speed of the flap is now changed! If you want to loop the animation, please follow the C-4 instructions. |
C-4 |
When you adjusted the speed of swings, you can loop the swing animation. |
Make sure that Loop/Speed Switch box is checked. |
Play the animation from the beginning to see the result. Swing loop is now finished. |
