In iClone's physics system, the Dynamic and Frozen rigid body objects drop or drops after being hit (respectively) by the effect of the gravity. However, if you want to limit the dropping behavior to a certain range, then the Constraint feature can assist you in achieving this purpose.
Note: |
The non-constrained rigid body drops to the floor. |
The constrained rigid body remain where it is as you play back. |
