Prop Puppeteering (New for 5)
The Prop Puppet feature helps you move your mouse and trigger the prop to transform, while the transform animations are all being recorded.
This method saves time when setting a bunch of individual keys for moving, rotating or scaling; in addition to that, the smoothness of the animation
is higher that what you can achieve by manually adding keys.
Select a prop.
Click the Prop Puppet
button to open the panel (Shortcut: Shift + F2).
Select a mode (Simple and Advanced) for puppeteering.
Press the Preview
button and then the space bar; move your mouse and preview
the movements of the prop (Shortcut: Space bar).
Press the Space bar to stop previewing.
If you are satisfied with the preview result, then press the Record
move your mouse and record the movements of the prop (Shortcut: Alt + Space bar).
Press the Space bar to stop recording.
Note:
The speed of the prop animation depends on the speed of your mouse movement.
You may use this method to control a
Kinematic rigid body to collide into other physics objects.
The recorded result will be stored into the Transform track in key type.
See also:
