Issue 10641
Send to iclone 8 from CC4.3 fails
After using Headshot1.0 to add a head to a cc3+ body, the command to send to Iclone seems to work, but Iclone says "failed to load file". I have tried various bodies, all cc3 or cc3+ but nothing seems to work.
I have also tried to save the figure as an iAvatar. But iclone 8 will not import the saved iAvatar. Errors are:
"Failed to load the file"
"Import failed - "
"No standard/humanoid character is picked"
"Import failed - C/users/wayne/appdata/localtemp/vharactercreator4temp/temp/imotionplus"
I had Headshot 2 trial installed, but even after I uninstalled it and restarted the computer, the same thing happens.
Process is
Load character CC3baseplus
Open headshot
Drag png photo into headshot
Select figure with new head
Select file/export/send to iclone/send to iclone
Go to Iclone 8 and see failed to load the file message
Submitted bywaynewiz16
Jul 4, 2023
