Votes
0
Product:
Character Creator 4
Version:
4.32
Status:
Not a Bug
Issue 11249
Inverted Gizmo
I do not know if this is a bug, but it appears like one to me.
When an imported character is too small (couldt find out from which size on) and you import another object, for instance
an obj eyeball as accessory, them move it around, scale it etc. all over sudden the gizmo inverts intself into the wrong direction.
So when usually when pulling the mouse , beginning all the way from the left to the right, an object usually rotates into that direction,
the gizmo begins rotating the object into the opposite direction. This happens sometimes directly after import, sometimes after the object has been
placed, all over sudden and cant be reverted until you start a new session.
This happens on CC4.32 and 4.4 as well.
See short video here: https://forum.reallusion.com/550800/Gizmo-inverted-when-char-is-too-small-
OS: Windows 10
  •  2
  •  181
Submitted byK_Digital Apr 13, 2024
COMMENTS (2)
K_Digital May 10, 2024
I am not shure which file i was using. According to the date of this posting it should be one of the ones provided below. IIRC i was using e1r and e1l which were extracted from a CC3+ character.
Feedback Tracker Admin May 13, 2024
Hi K_Digital,
You can change to Local Rotate in Toolbar and try it again.
Molly
Reallusion
Feedback Tracker Admin May 10, 2024
Hi K_Digital,
Can you provide your eyaball file to us?
Molly
Reallusion
