Issue 10697
Headshot 1 extremly buggy in CC4.31
Hello, I have just purchased Headshot 2. The Hub auto Updated CC4.x to CC4.31 , then installed Headshot 2. Headshot 1 is also still available, which i find great, but i discovered some serious bugs.
Headshot 1.01.0927.1 , CC4.31
CTRL+V does not work properly, works only randomly sometimes or not at all, or when using it in generate character window (with the characters baby etc) the image is used for a face creation, but does not show on the left and shape adjustment etc is not
available. Besides CTRL+V does not work at all when freshly starting CC4. Only after clicking on Headshot 2, STRG+V, close Headshot2,
and then use Headshot 1 with STRG+V, but then very buggy as described above. Importing an image through the load image button seems to work normal.
Please see zip with several example screenshots
hs1a - STRG+V used in the generate character window (left window is empty)
hs1b - Opened using the load image button
hs1c - CTRL+V in the right window
hs1d - next step after clicking generate on hs1c
hs1e - this happened after while hs1d was visible and dbl clicking on the left window, then pressing STRG+V, then generate
Headshot 2 seems to work as expected in this regard
This all brings me to the question if i can safely install headshot 2 on my other Windows 7 machine without ruining my working Headshot Setup. Just want to make shure because of that recent Phyton Plugin Menu issue i am double careful before updating something there.
After doing some more testing i slowly come to the idea both plugins may not work on the same install. Example: when making aface with HS1, then pressing Shift+Q does all kind of weird things.Sometimes it works, sometimes not, makes the Headshot 2 Icon blink sometimes, mousewheel wildly zooming around the lens factor while zooming in main view, character completely disappearing sometimes etc.
Submitted byK_Digital
Aug 2, 2023
