C-1. |
Attach the props which were just placed to the appropriate location to the Body of the Creature Base. |
Tip. If a prop is too big, it may block the bone causing it hard to choose the bone when trying to attach. |
Please choose the prop and execute the Freeze command. Try attach again, and it should work fine now. |
After all the props are attached to the bone, go to Scene manager and unfreeze all the props to make sure that they can be relocated later. |
C-2. |
Attached the Joints. |
Attached the Fingers |
Attached the Compartment. |
Attached the Guns |
C-3. |
Hide the Creature Base Bone.
Choose the character, and go to Actor/Skin/Material&Texture Setting. Hide the material of each part. |
Tip. If you want to fine tune the attached props, you can easily do so by clicking on the Select tool. |
