Crazy Talk Animator provides 2 kinds of iProps, you can learn how to use them as below. |
A |
Use iProps controlled by Sprite Editor. |
B |
Use iProps controlled by Action Menu Editor. |
For more details, please follow the step-by-step instructions below. |
A. Use iProps controlled by Sprite Editor. |
An Interactive Prop (iProp) has at least 2 sprites, and user can switch between the sprites freely. |
A-1 |
Apply an Interactive Prop. (eg. Tire.) |
A-2 |
Click Sprite Editor to select the Front Tire_Loop_Ani sprite. |
A-3 |
Click Play to see the difference in the Viewport. |
Link other props. |
B. Use iProps controlled by Action Menu Editor. |
An Interactive Prop has multiple sprites and is controlled by command. User can choose different command from the Action Menu. |
B-1 |
Apply an Interactive Prop.(eg.Front Door.) |
B-2 |
Click Action Menu Editor to open the Command List. |
B-3 |
You can click on Open to see the animation. |
B-4 |
Done |
