![](images/index_01.jpg) |
You can easily assemble a vehicle |
A |
How to assemble a car. |
B |
Replace/ assemble car elements in the Composer Mode. |
C |
Change the color of the props in Composer Mode/Color Editor. |
For more details, please follow the step-by-step instructions below. |
A. How to assemble a car. |
We have set components' locations and layers for each car's components. You only need to load the car to the stage and you can see a completed car. |
Take the police car's front for example. |
A-1 |
Go to Scene > Props and click Police car's folder. |
A-2 |
Load every props to the stage and you will have an assembled car. |
![](images/HELP/Help01/1-04.jpg) |
A-3 |
Link the props to the Car Body.
Choose the props and select Link, and then click the Car Body. |
Link other props. |
B. Replace/ assemble car elements in the Composer Mode. |
You can replace any car's components and adjust the location of them. |
Take the tire for example. |
B-1 |
Click the props that you want to replace. |
![](images/HELP/Help01/1-08.jpg) |
B-2 |
Switch to Props Composer Mode. |
![](images/HELP/Help01/1-09.jpg) |
B-3 |
Double click the tire pattern to get the replacement. |
B-4 |
After replacing it, go back to stage. |
![](images/HELP/Help01/1-13.jpg) |
B-5 |
You have Replaced the props without changing its position. |
C. Change the color of the props in Composer Mode/Color Editor. |
Take the scooter for example. |
C-1 |
Click the props that you want the color to change. |
![](images/HELP/Help01/1-24.jpg) |
C-2 |
Click the Color Editor in Props Composer Mode. |
![](images/HELP/Help01/1-16.jpg) |
C-3 |
You can change the color of it. |
C-4 |
If You want to change the color of the mark on the scooter body, please select fairing_02 in Scene Manager and adjust it. |
![](images/HELP/Help01/1-20.jpg) |
C-5 |
When you finish editing, please click Back to Stage. |
C-6 |
Edit the color for other props, and then you can change the color of the entire scooter. |
