Transform Section
When you want to set the size, orientation and location of an imported model as it is applied into iClone, adjust the transform data of the model by typing values into the Move, Rotate and Scale fields.
Alternatively, you may also press down or drag the up/down arrow buttons of each field to change the the value.
  • Aligning Nodes
  • Resetting Transform of Modified Model
