Sometimes the model or the mesh nodes may not be built on the center of the scene root. You can align them by means of the Align to Center button. You can also align the pivot of the model, a node, or specific nodes to the scene root. The Align to Ground, however, aligns the bottom center of the bounding box for the model.
Please note that the aligning feature only works to the Scene Root or Sub-Prop nodes.
Load a model with meshes.
Select the nodes. Click the Make Sub-Prop button to generate one of their Sub-Prop nodes.
Click the Align to Center or the Align to Ground button in the Transform section.
The Sub-Prop, in accordance with the center or the bottom center of the bounding box, will be aligned to the origin.
Align to Center |
Align to Ground |
