The term Behavior Switch means to change an Actor's Persona or iProp's Action Behaviors.
Diagram of the AML file |
Actor |
The AML file is either embedded or imported
Each AML file contains one or more
Pressing the
X key (in Director Mode) will
Alternatively, select a mode from the |
You can use Hotkeys or |
Also see:
If you have an actor and an iProp connected using the Attach to function, the actor will have access to the iProp's presets.
Actor and iProp Attached |
Also See:
