IK, FK for Non-Human Actor
If you have non-human actors in iClone, you may use IK and FK to adjust
the poses and generate motions.
Right-click on the non-human actor and select Motion Menu/Edit Motion.
Select the Rotate
tool in the
control bar.
Click on the non-human actor to pick a bone. Alternatively, you may pick
a bone by clicking on the node in the
tree view in the Edit Motion Layer panel.
Click on the actor to pick the bone.
Click bone in the panel.
Drag the Left Mouse Button to rotate the selected bone.
Please refer to the What is IK/FK and
How to Use FK sections for more information about FK.
IK for Non-Human Actor
Since IK relates to a chain of nodes, then it is necessary to anchor the head of the chain
in order to move the
end node with IK method.
Select the Move tool in the
control bar.
Hold down the Ctrl key and click on a node to define it as the
start of the IK chain. It will then be marked with a blue box.
You may Ctrl click again to cancel the anchor.
Please note that you may also click or Ctrl-click on the target node inside of the Edit Motion Layer panel.
Pick another node to be the end node of the chain.
(Ctrl key released)
Ctrl-click to anchor the start of the IK chain.
Click another bone as the end of the IK chain.
Drag across the 3D viewer to modify the whole chain with IK
control.
How to Use IK sections for more information about
IK.
Note:
If you intend to set a node as Absolute, then check the box next to the node in the
For more information about Absolute/Relative, please refer to
the
Absolute and Relative Bone section.
You may also refer to the
Select Bone section for more information
about the IK Constrain and the Mirror features.
