1 |
Collapse/Expand |
Click the button to collapse/expand the Content Manager or Scene Manager individually. |
2 |
Show/Hide |
Click this button to show/hide the pane of the Content Manager and Scene Manager. |
3 |
Resize |
Drag the border to resize the pane of the Content Manager and Scene Manager. |
The content manager is used for managing the various iClone 3D files including models, animations and contents associated with a project.
1 |
Folder Editing Tools |
2 |
File Editing Tools |
3 |
Rename |
4 |
Capture Thumbnail |
5 |
Load Thumbnail |
6 |
View |
7 |
Find File |
If you do not select any file and click this button, then iClone will open a new explorer with the path: Windows XP C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\(current tab)\ Windows Vista/Windows 7 C:\Users\Public\Documents\Reallusion\Template\iClone 4 Template\iClone Template\(current tab)\ |
8 |
Overwrite |
9 |
Add |
10 |
Apply |
* Clicking on the Modify Time header to sort content can help you find recently added contents more easily.
*In most cases the content manager has two tabs, Template and Custom. The Template tab contains all the predefined content. The Custom tab contains all the custom content you have created with iClone and saved to the various Custom asset libraries.
The Scene Manager displays all the objects and actors included in the current project. You may select multiple items, show/hide the objects altogether, or even adjust the render state of them. It also shows the face count of each object for your reference.
1 |
Object Selection Tools |
2 |
Renaming |
Click on the desired object once to select it, click on its name again shortly after to enter the name-editing mode. You may rename all the items as you wish. |
3 |
Freeze Status |
Check the box so the object can not be picked in the Preview window. Please refer to Locking and Freezing Camera for more information. |
4 |
Show/Hide Status |
Show or hide the selected object. This status does not affect the export result. |
5 |
Render Status |
General Objects: You may specify the render status for each object to relieve the load on system resources. This status does not affect the export result. The status includes:
Light: You may turn the desired light on/off by checking the on box on/off in the Render State column. You may also change the color of the light. Path: You may change the color of the path in the Render State column. |
6 |
Information |
The information may change according to the properties of the individual items. Light: You may turn the shadow-casting ability of selected light on/off by checking the Shadow box on/off in its info column. Video: You can decide if the imported video is a still image or dynamic when the project is playing by checking the Still Image box on/off in the info column. Other Objects: Info column shows the face count of each item. |
Note: |
Some items such as water, trees, grass, particle emitters, terrains can not be selected or are difficult to be selected from within the 3D viewer. Use the Scene Manager panel instead to select them easily. The Scene Manger will also show the parent/child node structure of a 3D object so you can use this behavior to select the child node directly.
The Show/Hide status of each item will be saved to iClone project files. |
