![](../images/ct5/feature/tadle_01.gif) |
Blazing Visual Experience for CrazyTalk |
![](../images/ct5/feature/blister.gif) |
Rich Library of Special Effects as Default Content
65 templates of special effects
in the Disguise, Metaphors and special category to add
comic effects for your characters.
![](../images/ct5/feature/feature_effects02.gif) |
Rich Library for Customizable SFX Effects ![](../images/ct5/feature/pro.jpg)
58 templates of special effects in 4 categories, Facial Action, Full Screen, Illustration, and Transition, to satisfy your most common demand for animated expression or message delivery.
![](../../images/ct4/ct45_effect_1.gif) |
New Text Bubble SFX for Comic Captions ![](../images/ct5/feature/pro.jpg)
CrazyTalk5 provides new Text bubble for comic captions and tilting effects. 32 Text Bubble SFX templates allow you to type
messages in the text bubble by clicking the SFX on the
sequence interface to bring dialog box and adjust the
text.
![](../images/ct5/feature/feature_effects05.gif) |
Dual-layered Special Effects ![](../images/ct5/feature/pro.jpg)
Dual-layered special effects allow
you to swap SFX from foreground to background with “SFX-Swap”.
![](../images/ct5/feature/feature_2.gif) |
Custom Image and Animation File Import
CrazyTalk allows you to import an AniGIF
, JPEG, BMP, TGA or PNG file as an animated object, illustration,
or full frame content. Loaded image sequence comes with
alpha channel and allows users to perfectly overlay
animated objects on talking images, producing smooth
edge and transparency. CrazyTalk5 supports alpha-ready
file format including Targa or 32-bit bmp. Background can be removed manually by using the mask editing tool.
![](../images/ct5/feature/feature_effects03.gif) |
Manage Your Own Custom Special Effects Library
After creating a new effect, you can choose the image of thumbnail for your custom special effects library.
![](../../images/ct4/ct45_effect_4.gif) |
Modify and Fine-tune Special Effects
Whether it is a template stamp effect
or your own creation, you can specify object location,
size, transparency, and the speed of the effect, to
fully control how the animation appears in your video. |
![](../images/ct5/feature/feature_effects04.gif) |
