Getting Started - Creating a CrazyTalk Script
Some features are for CrazyTalk 5 PRO Edition only. For more information, please see Version Information.
The Script page is the critical phase in CrazyTalk's process of creating a talking message. Here you decide what and how your model talks and specify the expressions, facial movements, and special effects that go along with the animated script.
Note: You can download the text-to-speech converter from Microsoft, or browse to Reallusion's website for more information.
To create a Talking Message:
  1. Click New button to start a new script without any keys.
  2. To specify the speech for the talking model, do one of the following:
Click the Record button to start recording. Recording from the specified audio source starts.
  1. To insert background music, click the Background Audio button.
    1. Click the Browse button to import a song or musical track in PCM WAV/MP3 format.
    2. Move the Volume slider to adjust the volume.
    3. Check the Fade In or Fade Out options to specify if you want the background audio to fade in or out respectively. Check the Loop box to repeat the background music continuously.
    4. Click Preview to play back the background audio.
  1. To select an expression profile, click the Emotives tab to view a set of basic profiles such as sad, angry, happy, and so on. Select the desired profile from the library and double-click it to apply.
  2. Click the Timeline tab to edit the animation script.
    1. CrazyTalk provides basic editing tools to cut, copy, paste, or delete portions of the track. Use Cut ,Copy , Paste , Delete to edit the track.
    2. You can view the complete script or enlarge portions of the sequence using the track viewing tools.
      • : Zoom in.
      • : Zoom out.
      • : Zoom to selection - Drag to select a portion of the Timeline to enable this button.
      • : Zoom Out Full - Zoom out and view the complete script in the sequence window.
  3. Edit keys in the tracks:
    1. Double click on each track to invoke the related dialog box for further editing.
      Track
      Double Click
      Description
      Voice
      Select all tracks.
      Lips
      Invoke Lip Synching dialog box.
      • Select desired template.
      • Adjust the strength.
      Face/Face Strength
      Invoke Facial Expression dialog box.
      • Adjust the strength of the expression.
      • Modify the Facial Feature and Muscles.
      • Add/Delete customized template.
      Head/Camera
      Invoke Key Editor dialog box.
      • Set keys for Head, Camera, Facial Muscles, Eyes, and Shoulders manually or automatically.
      • Specify the Facial Muscles in an Expression key.
      Eyes
      Shoulders
      SFX/SFX-Swap
      Invoke the Special Effect dialog box.
      • Select Image Theme, Image Overlay, and Text SFX as special effect.
      • Type texts as the contents of the text special effects.
      • Two tracks of SFX for creating more special effects in the front or background of the image.
    2. Pick Head/Camera, Eyes or Shoulders in the Key Editor dialog box, drag on the sample image to adjust the model, and click Set Key to add a key into the timeline. Check the Auto Key box to update the key automatically instead of pressing Set Key manually.
    3. Click Puppeteering button to invoke the Puppeteering Panel to create custom motion clips. A motion clip will be overlapped as the top layer of the Face, Head/Camera, Eyes or Shoulders tracks.
      To create a motion clip:
      • Drag to select the desired portion in the Motion Clip track and click Group button.
      • Select a Puppet Profile and full face control, click Preview button and press Space bar to view the result. Click Record when you are satisfied with the settings.
      • Pick one desired profile and click Record button, press Space key to start recording the motion clip. Move your mouse so the model will be driven to move, and the movements will be recorded simultaneously. Press Space key again to stop recording.
Note:
  • Click Add to add the desired motion clip into the motion clip gallery.
  • Alternatively, you may drag and drop the desired motion clip from the motion clip gallery onto the Motion Clip track.
