![](images/Help_Button/HELP02.jpg) |
All the Ceiling, Floors, Pillars and Walls are separated into Brick & Concrete categories. Each Building Element has its unique characteristic. Please see below for detailed information: |
A |
Ceiling & Floors are surrounded by virtual walls. |
B |
Pillars that can change the explosion direction and choose the explosion timing. |
C |
Composable Walls |
D |
Glass that will fall to the ground or keep falling. |
For more details, please follow the step-by-step instructions below. |
A.Ceiling & Floors are surrounded by virtual walls. |
Ceilings & Floors are designed to be surrounded by virtual walls. |
Items below are surrounded by virtual walls. |
Items below are not surrounded by virtual walls. |
Ceiling / Floor 1-1 |
Ceiling / Floor 1-2 |
Ceiling / Floor 2-1 |
Ceiling / Floor 2-2 |
Ceiling / Floor 3-1 |
Ceiling / Floor 3-2 |
Ceiling / Floor 4-1 |
Ceiling / Floor 4-2 |
Example of usage: |
B.Pillars that can change the explosion direction |
There are two choices of pillars which are cylinder and square. |
Pillar 1/2-Plus includes three parts (Top/Middle/Bottom) that can be selected. |
Example of usage: |
C.Composable Walls |
Wall L-1~3 : The left walls are used for assembly purposes and it provides three different height of explosions. |
Wall R-1~3 : The right walls are used for assembly purposes and it provides three different height of explosions. |
Wall M : The middle wall are used for assembly purposes. |
Example of usage: |
D.Glass that will fall to the ground or keep falling. |
Provide two types of exploding glass, so you can make films with window explosion in a building. |
Example of use: |
![](images/Help/02-08.jpg) |
