How to Use the Flap Dummy? |
Introduction of the Flap Dummy |
A. |
Turn on the Flap Dummy. |
B. |
Change the speed of the flaps. |
C. |
Change the distance between the wings. |
D. |
Structure of the Flap Dummy. |
For more details, please follow the step-by-step instructions below. |
A.Turn on Flap Dummy.
You can use any Assembled wing directly, because they are made up of Flap Dummy.
B.Change the speed of the flaps
You can change the speed of the flap in the Timeline. |
B-1 |
Follow A-2.''Right-click to select Perform/Flap Light'', and generate the flap animation clip. |
B-2 |
Select Flap_L in the Scene Manager, and open the Timeline. Make sure that Loop/Speed Switch is not checked. |
B-3 |
Select the Animation Clip in the Perform Channel, and drag it. |
Flap_L & R are connected to each other, so you only need to operate one to finish the flap editing. |
B-4 |
The speed of the flap is now changed!
If you want to loop the animation, please follow Step.A. |
C.Change the distance between the wings.
C-1 |
Apply any Avatar, and Apply an Assembled Wing in Actor/Accessories. |
C-2 |
Select Flap_L/R in Scene Manager, and move Flap_L/R to where you want via Transform. |
C-3 |
You can follow Step.A to see the result after changing the distance between the wing. |
D.Structure of the Flap Dummy.
All Assembled wings are made up by Flap Dummy. You can see the Structure of the Flap Dummy as below. |
In order to assemble your own wing, please follow the step-by-step instructions below. |
D-1 |
Apply and move segments, and select all attach to Flap Dummy. |
D-2 |
Select segment that will be the right-side in Scene Manager. |
D-3 |
Click on the Attach to in Modify to open Attach to Sub-Node. |
Attach the Segments that will be on the right-side to Wing_R
Attach the Segments that will be on the left-side to Wing_L |
