1. |
Go to Avatar and select the G5 Character – Gwynn under the Content Manager window. |
2. |
Select the character in the stage and go to Spring under the Modify window. Click Export Setting and save it as a .spx file. |
3. |
Double-click the character Wanda under the Content Manager window. |
4. |
Select Wanda in the stage and go to Spring. Click Import Setting and import the .spx file you just saved. |
5. |
You may save the character that you just applied Gwynn's spring to. Click Plus under the Content Manager window to save the character. |
6. |
Apply the Avatar to the stage and adjust the parameters of Spring to create the effects you want. |
7. |
Spring effects are done. |
