A. |
Adjust default values to change character costume colors in iClone5 |
You can quickly adjust character costumes using the default tools in iClone5. |
A-1 |
Apply a character and choose "Upper Body" under "Actor". |
A-2 |
Click "Diffuse" in the Modify window. |
Adjust the values under "Adjust Color". |
Adjust the Brightness, Contrast, Hue and Saturation as you like. |
A-3 |
Done. |
B. |
Use graphic software to design a texture |
You can export your character's costume texture, import it into any of software that you installed on your computer, and then change the costumes by drawing the textures. |
B-1 |
B-2 |
Click the "Launch" button under the "Material & Texture Settings" in the Modify window. |
B-3 |
Draw the texture in the graphic software. |
After changing the texture, you can either save or reload the file to update the texture. |
B-4 |
Done. |
For a more detailed walkthrough, please check iClone 5 Online Help: |
CloneCloth - Creating Your Own Fashion Designs and Collections |
