Issue 7544
iCar Body Shop No Longer Working Properly??
Hello Tech, and Happy New Year! šššššš
I want to be able to make my own custom body cars using this particular system (i.e.,
https://3dwarehouse.sketchup.com/model/61e29a0a6be803f72f2303161abacc54/Car-Turntable-4800mm-Diameter-Paver-Riser-option ), for my upcoming movie creations (Nostalgic, honoring the past of iClone content), but I can't get the wheels to turn using this system. Everything else works fine, even the perform commands. I followed two build instructions, both in which are very detailed instructions, where following either should give the same results of functionality:
https://www.reallusion.com/ContentStore/iClone/pack/iCar_BodyShop/Help_Assemble.aspx (your instructions)
https://www.youtube.com/watch?v=FRHZBSTgsZw (foreign language, but SUPER easy to follow)
In the example, you will see that my remake (right side) doesn't have the same take off, nor do the wheels even work at all. In the ORIGINAL make (left side), the wheels turn inward for some reason now.
So, it's CLEARLY obvious that there is a problem with this pack/scripting setup. Please fix this, so I can use this in my movie(s).
Thank you in advance for your help!
Submitted byLogicalWarrior
Jan 3, 2021
