Votes
0
Product:
CrazyTalk Animator 3
Version:
3.32
Status:
Closed
Issue 6992
crazytalk animator 3 user interface too small
Crazytalk animator 3's user interface is too small to work with the program. Is there a way to make the interface and fonts bigger?
OS: Windows 10
Related Issue:   UI Scaling (Issue 6926)
  •  2
  •  1669
Submitted bywoestyn101 Jun 25, 2020
COMMENTS (2)
woestyn101 Jun 29, 2020
Thank you so much for this advice. It solved my problem.
Feedback Tracker Admin Jun 29, 2020
Hi woestyn101,
Please try the following steps and see if it works:
1. Right click on the CrazyTalk Animator 3 application icon and click “Properties.”
2. Go over to the “Compatibility” tab
3. Under “Settings”, click on the “Change high DPI settings”
4. Under "High DPI scaling override”, check the “Override high DPI scaling behavior”, using the drop-down menu to select to “System” or "System (Enhanced)"
5. Click on "OK", and "OK" to apply the changes
6. Restart CrazyTalk Animator 3 and see if there is an improvement.
Irving
Reallusion
