Votes
Product:
3DXchange 7
Version:
7.4
Status:
Active
Issue 6926
UI Scaling
Hi,
Edit, Preference, Interface.
Iclone v7.41 - The option to change the icon & font size is available and works perfectly.
3DExchange v7.61.3619 - The option is not available
Character Creator v2.3.2420 - The option is not available
Surely the option to change the icon & font size should be the same with all Reallusion products.
Not having this option with 3DExchange & Character Creator makes the program unusable unless you have a magnifying glass.
The system requirements state:
Display Resolution: 1920 x 1080 or higher
I upgraded to a 75 inch screen and now cant see the font due to it being to small.
Scaling with Windows 10 display settings just increases header titles and nothing else.
Every other software program is usable and the same scale with my current settings
OS: Windows 10
  •  3
  •  4531
Submitted byRixy Jun 1, 2020
COMMENTS (3)
KBB23 Dec 17, 2021
The Option "Enlarge UI and Font" in CC3 is greayed out here.
Why that? Thx!
daniel_189101 Feb 25, 2021
It's good to know that Character Creator 3 already has the ability to "Enlarge Font and UI.
How do I access it?
Feedback Tracker Admin Feb 26, 2021
Hi Daniel,
Please go to Preference panel from Edit Menu,then check Enlarge Font and UI in System section.But font and UI will change big only when you use 4K monitor and set the size of text,apps,and other items to 150%.
Molly
Reallusion
Feedback Tracker Admin Jun 3, 2020
Hi Gary,
Thank you for your suggestion.
Have you tried the application level GDI scaling?
Before we update our application, you can configure the GDI scaling feature for 3DXchange to make it scale better on the high resolution display.
Below is the steps to configure the GDI scaling for 3DX:
1. Right click on the 3DXchange  application icon and click “Properties.”
2. Go over to the “Compatibility” tab
3. Under “Settings”, click on the “Change high DPI settings”
4. Under "High DPI scaling override”, check the “Override high DPI scaling behavior”, using the drop-down menu to select to “System” or "System (Enhanced)"
5. Click on "OK", and "OK" to apply the changes
6. Restart 3DXchange and see if there is an improvement.
Character Creator 3 already has the ability to "Enlarge Font and UI"
You can apply GDI scaling settings to Character Creator 2. But Character Creator 3 is the version we recommended for working with high resolution display.
Please let me know if you have further questions.
Irving
Reallusion
