Votes
0
Product:
iClone 8
Version:
8.0
Status:
Not a Bug
Issue 8455
Warning message, not able to apply physics to a custum prop
iClone 8 show me an error when I try to enable physics to props (in this case, imported props from iClone 7). The prop I used is from my own RL Marketplace ( https://marketplace.reallusion.com/lego-dummy )
OS: Windows 11
  •  1
  •  376
Submitted byAndrés Moya May 13, 2022
COMMENTS (1)
Feedback Tracker Admin May 16, 2022
Hi Andrés Moya,
Thanks for your feedback!
This prop will pop up same msg in iClone 7 as well.
The reason why AP show up that msg is because the mesh you have selected name as Lego.
"Lego" didn't have any poly count, so it won't be able to turn physics as well.
If you select the 2nd node name as "base", it can turn on physics sucessfully.
Calvin
Reallusion.
