Issue 6457
Values for Near and Far Clipping Plane cannot be set independently.
The Near and Far values for the Clipping Plane for the camera cannot be set independently. The Clipping Plane seems to have been added in 3.2.
The default is a range between 0.1 and 999.0. When changing one of the values, the other one follows. For example, when setting Far to 9999, the value of Near becomes 1.
One undesirable consequence is that when setting the maximum value for Far (99999), the Near value becomes 10, thus cutting off the nose of a face when it is close, for example.
The issue can be easily demonstrated by changing the Clipping Plane values as described above.
The desired behavior is for the Clipping Plane values to be independently adjustable as in earlier versions of iClone (IC 7.7 has the same problem).
Submitted byanimagic
Nov 23, 2019
