Issue 8129
Texture resolution Swap for both Real Time playback & Rendering -for GPU/CPU & Native Render, Faster Physics Calculation etc -system wide speed increase
You provided the option to users to force the max texture resolution size for the entire project, how about based on camera proximity and a raycast from camera scan, props can be pre-calculated to reduce resolution? -what isn't seen by the camera and doesn't need to show in reflections is reduced to a fallback resolution?
At this time I'm forced to go through my project, split the project and or exported Iray Scene in parts the between start and end frames and either lower prop's resolution or increase it to get a faster render.
So while it's good that with Iray we can at least lower resolution for each prop and optimally apply it to those in the distance or close up if she shot is blurred anyway, I think we need to apply a dynamic smart resolution mechanism. The time and cost of Rendering and prepping for it is crazy if we don't change this.
I've requested instaLOD for iClone before but I think taking it a step further and prescan the scene would be ideal or just convert all the props with InstaLOD. InstaLOD will create a lot more files and calculation time which users may not be able to afford so instead if you can make it an option to reduce the texture resolution & compression only rather than making a new file this would be ideal.
Submitted byAscensi
Sep 21, 2021
