Votes
Product:
iClone 8
Version:
8.23
Status:
Active
Issue 10565
Support for Expression Layers on Timeline
The system needs support for layers for expressions like it has for body motion so that animation can be built incrementally using keyframes (Face Key) and Face Puppet (or Mo-Cap).
As it is, if you attempt to do Face Puppet "over the top of" a clip based on keyframes (from Face Key), the discrete Face Key-generated keyframe are obliterated (flattened). There should be separate tracks so they can be viewed and edited independently (while being blended/mixed when played back).
OS: Windows 10
  •  2
  •  235
Submitted bybarca-8 May 29, 2023
COMMENTS (2)
barca-8 May 31, 2023
Thank you for pointing that out. It appears I'd seen that ticket previously as I've already upvoted it :-)
The lack of layers/tracks is a constant source of frustration.
martin.mejzlik May 31, 2023
Hey, thanks for the suggestion. This has already been put in the tracker here: https://www.reallusion.com/FeedBackTracker/Issue/Animation-Layers-for-Expressions
Now it currently has 10 votes and I would suggest keep it in one place so the masters know what the plebs need ;)
