When lowering Interocular Distance the view indeed changes slightly but i doubt 1.0 for example is a real world distance. After some testing , It appers this error only happens when an object is "too small". I made the object 30 times larger with CC4.32, created a new project as described above, rendered to SBS without issues. So i assume the Interocular Distance may be not correctly calculated when an object is very small. Please compare the difference in size of both obj in the zips provided. The first one may be too small for proper use with this function. Hope this helps Regards Rolf
Hi K_Digital, I have transfer to our RD department and hope they can find out the reason.Thank you for your help. Molly Reallusion
Hi K_Digital, Can you change Interocular Distance and try it again? Molly Reallusion
Hi K_Digital, I can't repeat it with your project,but when I change Interocular Distance in Render menu,it will happen.Please change Interocular Distance and try it again.Thanks. Molly Reallusion
