Votes
0
Product:
Cartoon Animator 5
Version:
5.02
Status:
Assigned
Issue 9327
Problem reseting pose from Key editor
Having a large timeline with multiple keyframes and action poses, when adding Action presets from the save character menu, your unable to add keyframe to reset your default pose using Reset button from key Editor. Even copy/paste frame 1 will not work. The only way I found in my projet to reset is I had to use the "Sample motion clip" and everything works correctly afterwards.
OS: Windows 10
  •  2
  •  284
Bug
Submitted byRandy_Dice Feb 20, 2023
COMMENTS (2)
Randy_Dice Mar 1, 2023
exactly... it does not once you add a motion clip it will retain the last frame even if you are on 200 frames later with nothing in the timeline the only way to reset your pose and do more animation is to convert your motion clip 200 frame earlier into sample clip...
Feedback Tracker Admin Mar 1, 2023
Hi Randy_Dice,
This Reset key function is to reset the bone transformation for full body or selected body parts in the timeline motion track. Not resetting the data in Motion Clip.
Allen
Reallusion
