Issue 9247
Physics - Initial Force settings not working/overwritten
Hi,
When trying to use the 'Initial Force' settings for a prop. The values I enter, get overwritten with random numbers and nothing happens with regards to my settings entered.
I'm doing this with a project where the props are bombs being dropped from a plane wing.
https://prnt.sc/lhWODmW5ZEQU1. On frame 0 - I set it to the 'KINEMATIC' state in rigid body physics.
2. As the plane moves at the point I want the bomb to drop (about frame 530), I set the state to 'DYNAMIC'. I records the physics animation to the 950th frame.
3. The bomb drops as expected but I want to change where it lands. Where I am trying to use the Initial Force setting.
I set 'X' to say 500.
https://prnt.sc/5dbEp9LXL9zlI then run the animation again with the setting.
It does not work and I get my setting overwritten with random numbers or a number in the settings:
https://prnt.sc/ucckE1fH3-jGMy project is being hugely delayed due to this bug.
I need urgent help - I have flagged it to Mike Long as well via email.
Then when I run the physics
Submitted byAidemIndi
Jan 18, 2023
