Votes
27
Product:
iClone 8
Version:
8.22
Status:
Active
Issue 9505
Need option to disable auto-keyframing. Also, any property that's animated should be visible in the Timeline.
Need option to disable auto-keyframing. Most animation applications don't automatically add a keyframe every time you move an object like a light or camera or change the color of a material. At a minimum, there should be an option to turn that behavior off. Can't tell you how many times I've moved a light only to realize I wasn't at frame 0 when I did it. Then hit play and the light starts moving around. Not good.
Also, any property that's animated should be visible in the Timeline. As it is (for example), you can inadvertently add a keyframe for material color because you changed its value, but when you go to the timeline, there's no indication of what the change was and no way to edit it.
BTW: The options in your "General tag" section (apparently a required field) on this Feedback form are too limited and don't include obvious general categories like "Animation" or "Timeline"
OS: Windows 10
  •  9
  •  1055
Submitted bybarca-8 May 3, 2023
1 2
COMMENTS (9)
bradmballew Feb 23, 2025
Yes please fix this. This should be a basic feature of any animation program.
r.palermo101 Jan 15, 2025
They absoultely DO NOT care about their users. Have you tried their "learning" tutorials? I am so made I invested so much damn money into this program
panbeep Dec 20, 2024
Hello Reallusion. This is the most frustrating issue in iClone. How can you do this to us???? Every time I change something I don't want to animate the app adds keyframes.  Please Fix this immediately!!!
ReMark3Dcz Dec 29, 2023
The most frustrating task for any skilled animator. Completely incomprehensible, every animation tool has this feature. Just the camera views and peeks, the constant need to switch to another one to keep the original position without having to lock everything. Totally annoying, unintuitive, infuriating and a waste of time.
SalientFilm Oct 25, 2023
yoooooooooo thank you!! nothing like getting in the zone only to find out hours later everything is moving. lol. fuuuuuuuuuuuuuuuuuccc
1 2
