Issue 6583
Go Z Zbrush application not found, reinstalled Zbrush, still not found. Zbrush unable to update paths because of administrator admissions.
After updating CC3 to 3.21, my GoZ attempts result in an error message of:
"Zbrush application not found. Please verify your installation of Zbrush and try again."
My copy of Zbrush is currently Zbrush 2020, which came installed with GoZ as a plugin. After this first error in CC3, I reinstalled as an administrator Zbrush 2020. When I attempt to update my GoZ paths to CC3 via the preferences , or force reinstall the paths, or even check path to CC3, I get the error:
"An error occurred during installation. One possible cause could be unsufficient permissions in target application installation folder. Please run Zbrush as an administrator and try again to install the GoZ application."
I've ran Zbrush as an administrator and attempted this a few times now, but each time I get the error. If I try to do this with CC3 open, I get an alert that CC3 must be closed first. If I try to do GoZ from CC3 with Zbrush open, it still does not see Zbrush installed on my computer.
So I don't know what to do. If I just export, I get a solid mesh, instead of separate subtools.
Submitted bytswit0428
Jan 2, 2020
