Votes
0
Product:
iClone 7
Version:
7.01
Status:
Not Reproducible
Issue 3433
Flicker During PhysX Display - See Video Clip Linked Below
OS: Windows 7
  •  1
  •  1538
Submitted byCricky Jul 24, 2017
COMMENTS (1)
WayN Jul 28, 2017
Hi Cricky,
In the "Preference Section" → "Real Time Render Options" Is "TAA" (Temporal Anti-aliasing) ON in this case ? If it was on, does turning OFF helps ?
Does this material has any Displacement map or Normal map ? If so, does flicker happen if they are removed ?
It seems that the PhysX bounding wireframe is too close to the original mesh, but I am not quite sure.
Could you provide the simple project that could repeat this issue ?
And also the Microsoft DirectX Diagnosis info may help
To get the DxDiag file:
1. Select the "Start" menu, click "run" or press <Win Key> + <R>.
2. Input "dxdiag" & click "ok".
3. It will check your system for a while, after finish, click "save all information".
4. Save "DxDiag.txt".
You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and email the link with "FT3433" in the email title to feedbacktrackeradmin@reallusion.com. (or weienchen@reallusion.com)
Thanks
