Hi rowjlan, Because there is a Bridge in terrain,at 800 frames the character is under the bridge.The bridge is regarded as ground,so feet go vertical. There are two workaround. 1. pick character,open Modify panel Attribute tab,don't check Foot Contact 2. pick Bridge in Scene Manager,Modify menu > Convert To Prop Reallusion
Hello again - any progress with this?
Hi there, I saw you got the file. Any progress on figuring out what's wrong? thanks!
Hi rowjlan, I have got your file, we will check this issue. Thanks for your help. Reallusion
Hi, thanks for your reply. The file is too big I realize, so here's a link to it on Google Drive. Let me know if you have any issues opening it. The "vertical feet" issue appears about 800 frames into the timeline, after the character moves under the bridge. Thanks! https://drive.google.com/open?id=1OfWxbme7nfinfO0IQaPSAor-QE50SRaa
