Votes
3
Product:
iClone 8
Version:
8.0
Status:
Active
Issue 8558
Expandable Control Rig(s)
Control rig for IK biped / humans supplied with iClone 8 is great,
this suggestion is about usecases where one wants to animate non-standard characters in iClone, examples
• Four-legged (or more) animals
• fantasy creatures with reverse legs below waist, like a Fauns
• Characters with multiple arms
• etc.!
What's there now:
On extended bones, FK only, and/or select bones to form IK, then move bone chain in an IK manner.
Problem:
Only using the FK and select bone-chain IK is too tedious and unreliable for meaningful animation of extended bones.
For instance, one cannot lock the rotation or position of a leaf bone, which one moves in an IK manner, or control the rotations of intermediary bones of the chain.
Proposed solution:
Some built in facility to extend the control rigs, or create one's own control rigs
This could be something like:
• Constraints/"rules", pole targets and drivers available for use with the existing IK and FK system
• iClone proprietary rig controller object that can perhaps be attached to Avatar objects, like with the reach target system
• Node system to set up relationships between bones
• Python script API for controlling bones
UX wise suggestions
• integrated as an own tab on the modify motion panel. e.g., | IK | FK | Custom Controls |
• Can be set up entirely within CC4 first prior to going into iClone
• Separate area in the Curve Editor
I will make no assumption about the market for this solution. But I daresay, it would open up a wider range of animation usecases which does not revolve around the frame of human only characters.
iClone has an advantage in speed, ease of use and quick turnover for animation, but one likely must pursue using other software the moment one want to make a lengthier animation of something that's not biped/human, which is unfortunate.
Thanks to Reallusion team for any consideration. Best,
OS: Windows 11
  •  1
  •  421
Submitted byper.furre May 31, 2022
COMMENTS (1)
Ascensi Apr 21, 2024
This is the same reason why I suggested a particular idea to more easily make it happen by the devs. Users may have to create a matching bone alias in CC4 if the developers can make it happen but Ideally if used cloned or renamed bone hierarchies  that match existing arms, legs etc the system should easily be able to switch to a different arm or legs set that was pre-created in CC4 but during animation/mocap time, switch to the bones that will be in use from the presets.
https://www.reallusion.com/FeedBackTracker/Issue/Essential-Multi-Body-part-Characterization-Bone-Preset-Switching-for-Mocap-Edit-Motion-Layer-Motion-Correction-Puppet-Motion
Either by creating creatures from scratch or making bone name alias we should be able to do this without a major rewrite and I think would be a smart way to implement it. They may have started working on quad+ support from rumors i've heard but if not, I need more votes, it's likely better to suggest a easy way for devs to implement such request without having them think they  would need to rewrite from scratch otherwise we might wait years for a change.
