Votes
0
Product:
Character Creator 4
Version:
4.42
Status:
Assigned
Issue 11447
Edit Pose Window Not Available
Edit pose window does not show, so unable to pose character with x mirror function. Come on Reallusion.......this has been an unresolved issue since I purchased CC4 almost 3 years ago. SO TIRED OF YOUR COMPANY. FYI, Headshot 2 sucks.
OS: Windows 11
  •  3
  •  134
Bug
Submitted bymdl1690 Aug 1, 2024
COMMENTS (3)
mdl1690 Aug 2, 2024
Molly,
Neither suggestion works. To clarify, I’m talking about CC4, but I checked and also not showing in iClone. Also Face Key is not showing in iClone.
Regarding Headshot, I use highly detailed meshes from Vface, similar to the ones in Scan Reality Pro.
Feedback Tracker Admin Aug 13, 2024
Hi mdl1690,
Although there is a workaround, we hope to solve the problem from the root.So can you save IC8 current user registry to us?
Step1:
Press "Win + R" button on keyboard,then key "regedit".
Step2:
Copy & paste below path in Registry panel,then right-click on 8.0 folder,and choose "Export",save a registry file to us.
Computer\HKEY_CURRENT_USER\Software\Reallusion\iClone\8.0
Please attach the file in your next comment. You can use Private Comment.
Molly
Reallusion
mdl1690 Aug 7, 2024
Hi Molly,
Thanks for the tool. It has solved the issue. Much appreciated.
Michael
Feedback Tracker Admin Aug 6, 2024
Hi mdl1690,
I see your picture seems to about Local Machine of registry, not Current User.You are not an isolated case, but some people have solved it through previous methods.
I have created a tool to help you delete it.Please download it and double-click,then launch CC.Thanks.
Molly
Reallusion
mdl1690 Aug 5, 2024
Molly,
Sorry, this also does not work. Note, there is no Dialog Position shown in my folder hierarchy to begin with. Am I the only one with this problem?
Michael
Feedback Tracker Admin Aug 5, 2024
Hi mdl1690,
Thank you for your response.I know you said CC4.There is also "Edit Pose" in IC8,just its name became "Edit Motion Layer".I guess IC won't be able to open this panel.Can you help me try another method?Because we
can't repeat it,so we need your help.We also really want to solve this problem.
Step1:
Step2:Delete CC4 "Dialog Position" from this path
\HKEY_CURRENT_USER\Software\Reallusion\Character Creator\4.0\Dialog Position
Step3:
Launch CC4 and try it again.
Molly
Reallusion
mdl1690 Aug 2, 2024
Hi Molly,
The edit pose panel doesn’t open or show at all. So no access to Mirror posing, IK, or Keying Mode. I have reported this among other bugs several times, but no fix. Frustrating because many users have the same issues. Regarding Headshot, the quality is underwhelming. The level of detail it can capture is very low. The results are a mere resemblance of the original. You need to spend additional hours in an external software like Zbrush in order to get a model with surface details, and bake proper normal, cavity and displacement maps. And you need to buy Face Tools in order to use Zbrush to do what Headshot can’t.
Feedback Tracker Admin Aug 2, 2024
Hi mdl1690,
Did you use multi-screens?If Yes,please try this two methods:
Method1:
Open Window menu in iClone,choose "Workspace > Standard"
If you still can't open panel,please try Method2.
Method2:
Please Open Computer Display settings,Multiple displays choose “Show only on 1”.
About Headshot,did you use photo to head or mesh to head?
Molly
Reallusion
Hi mdl1690,
I'm very sorry for the inconvenient.Do you mean that you can't open Edit Pose Panel?Can you tell me what problems you encountered while using Headshot2?We will do our best to solve your problems.But we need you to tell us more information.
Molly
Reallusion
