Votes
0
Product:
iClone 8
Version:
8.52
Status:
Active
Issue 11775
Crowd Generation Tool - iClone 8.52 - inpossible to work with - without docking - edless goes off the screen
60" monitor - 4k- even minimal scale of 100%(Windows 11 recomends 300%scale) and despie using minimal font size in iClone (text becomes 4mm - impossible to read from - 4 m) even WIndows recomended 350%) =the Crowd Generation Tool = NOT POSSIBLE TO DOCK = REVISE YOUR SOFTWARE AND MAKE IT ABLE TO DOCK ??? =
The meny was way too long - beyond the bottom of screen (125%) - without -docking feature - for this pannel it is impossible to work and acces the bottom button.
even with 2 vertically positioned monitors = and the same happened when I was using 1 - monitor only.
also with 100% scaling = the text on the monitor is way too small (4 mm text = watching from 4 m???)
I am sure your programers can do a better job. In adition - fix this quickly - or I will return this product
OS: Windows 11
  •  1
  •  73
Submitted bybranko222 Jan 22, 2025
COMMENTS (1)
Feedback Tracker Admin Mar 7, 2025
Hi branko222,
Thank you for your feedback. I will report this issue to the team for further investigation.
In the meantime, if you need to use the Crowd Generation Tool, you can try adjusting the panel length by dragging it from the title bar. This should allow you to access the buttons at the bottom of the panel.
Let me know if you need any further assistance.
Thanks!
Reallusion
jasmine
