Issue 11531
Creating a morph slider with an .obj TargetMorph doesn't work and causes stability issues
I'm using the trial version of CC4. I'll provide my full experience with this issue for more context
Initially, I was trying to create a morph slider following these steps:
1. Load Neutral_F into a clean CC4 project
2. Clear all morphs
3. Export to .obj as "Nude Character in Bind-Pose"
4. Import the .obj into Blender 4.2 using the CC4 plugin
5. Make a few minor adjustments to the face using the sculpt tool
6. Export the character to another .obj using the CC4 plugin
7. Choose create slider ("+" icon) in the Morphs tab
8. Enter name + path
9. Choose "current morph" as source
10. Choose the .obj exported from Blender as target
11. Make sure the correct *.objkey is selected
12. Tick "Adjust Bones" and "Auto apply to current character"
13. Hit OK
The message box with the progress bar just disappeared at 42% and the morph slider editor was still shown. No error message was thrown, no morph slider was created.
I gave it a few more shots starting from step 7, with altered checkboxes. I basically tried all possible combinations of options checked / unchecked, but got the same result everytime.
If I tried saving the project or loading a new character after this issue occured at least once, the application crashed.
To exclude Blender or the plugin from being the problem (For maybe corrupting the file), I tried to create a slider with the exact same morph target, by using the .obj file from step 3 -> Same outcome.
Next, I closed and reopened the application and tried to create a morph slider from CC4 Camila to CC4 Kevin, same outcome.
I also checked if the .obj import is broken in general, so I imported the obj files I created in the process just using the regular import function but all of them worked.
Minimal steps to reproduce
1. Create a clean project
2. Load in any character
3. Export as .obj
4. Choose "Create slider" in the same project
5. Choose the previously obj as the target object
6. Tick checkboxes as explained before (or leave it as is, as it doesn't seem to matter)
7. Hit OK
8. Watch it failing at 42%
9. Save the project to watch the application crash
Submitted bymaurerv
Sep 14, 2024
